AutoCAD 2010/2011/2012
Distinguished Contributor
jz4all
Message 1 of 6 (303 Views)
Hatch problem
303 Views, 5 Replies
09-26-2012 12:50 AM
When I use the avilable standard hatch, I have no problem.
But when I use custom hatch, I get nothing. The hatch doesn’t appear althought there are no errors or any unusual notices.
I tried to change the scale, or (select object), But no result.
All the layers are (on).
(fill) is ON+regen.
Linetype generation: ENABLED.
All these did not make the hatch visible. Any idea what can I do more?
PS: the standard hatch Works normal. the problem is only with custom hatch.
Distinguished Mentor
Moshe-A
Message 2 of 6 (276 Views)
Re: Hatch problem
09-26-2012 03:39 AM in reply to: jz4all
hi,
what about the hatch scale? try changing it to somthing much smaller or much higher.
even if you can not see it invoke LIST command and select it with "Last" object
does autocad catch it?
moshe
*Expert Elite*
Bob_Zurunkle
Message 3 of 6 (254 Views)
Re: Hatch problem
09-26-2012 09:04 AM in reply to: jz4all
Look at the command line history to see what the program was telling you as you did the hatch...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
jz4all
Message 4 of 6 (232 Views)
Re: Hatch problem
09-28-2012 06:59 AM in reply to: Moshe-A
Thanks for your reaction.
I mentioned this point above. I tried different scales from 10000 to 0.0000001, but no result.
By the way, beside the standard hatch, some of custom hatch work normale.
I don't know what is the reason?
Moshe-A
Message 5 of 6 (226 Views)
Re: Hatch problem
09-28-2012 10:36 AM in reply to: jz4all
it seems that the problem is in this specific custom hatch, can you post it here?
moshe
jz4all
Message 6 of 6 (199 Views)
Re: Hatch problem
09-30-2012 11:48 PM in reply to: Moshe-A
Hi Moshe,
You are right. The problem is in the hatchs. some of them works with scale 10 and others work in scale 1000000 ( by our exampel)!!!!
Strange! but I got the conclusion. that the problem with all of then is about the strange scale.
thanks again
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
