AutoCAD 2010/2011/2012
jpw777
Message 1 of 11 (6,527 Views)
Accepted Solution
HOW TO CREATE A MASK ? WITHOUT USING WIPEOUT COMAND
6527 Views, 10 Replies
11-05-2010 12:49 AM
Hi i want to put some line drawn furniture in my plans but i dont want the tiled floor to show through. As im constantly moving the furniture i can not  keep trimming the tiles out of the objects...is there a better way than using the wipeout command as this is so inaccurate and messes other stuff up.
Valued Mentor
Message 2 of 11 (6,522 Views)
Re: HOW TO CREATE A MASK ? WITHOUT USING WIPEOUT COMAND
11-05-2010 02:17 AM in reply to: jpw777
Are you drawing in 2D or 3D?  Is your furniture 2d lines or 3D solids?
dave
*Expert Elite*
3wood
Message 3 of 11 (6,510 Views)
11-05-2010 04:02 AM in reply to: jpw777
Two solutions:
1. Edit each furniture blocks, in the block editor, create an polyline along the outline, then convert it to a wipeout. Send the wipeout to the back of all other objects in a block. Ensure all tiling hatch is in the background.
2. Ensure each furniture block has a polyline as its outline. Create tiling hatch in the room with "Associated" option selected. When you move the furniture block, the hatch will be updated automatically (old AutoCAD version doesn't has this feature).
3wood
CAD KITS
AlistairBean1906
Message 4 of 11 (6,508 Views)
11-05-2010 04:04 AM in reply to: jpw777
If you are doing 3D models then your solid model would hide this for you.
Since you have been exploring wipeouts then I suspect that you are drawing in 2D and there is a clever little twist you can apply to solid fill hatches.
Within the block of your furniture create a hatch of the area you want to mask out, the pattern should be solid fill, and within the block draworder it should be sent to the back. The real trick is in the colouring of this hatch, most users will use colour 255 which is basically white, but the important colour is the printing colour in either the CTB or STB file, you need that to be the same as your paper (255 for white).
Hope this helps
AlistairBean1906
Message 5 of 11 (6,505 Views)
11-05-2010 04:07 AM in reply to: AlistairBean1906
I meant to add that another advnantage of hatches over wipeouts here is that they can be a more complex shape since wipeout boundaries can't include arc segments (or at least they couldn't in the past).
jpw777
Message 6 of 11 (6,417 Views)
11-07-2010 03:31 PM in reply to: AlistairBean1906
hmm seem like a great solution with the hatch on 255 and i understand it but when i print, our 255 prints grey and i dont want to mess with our internal plot styles. can i duplicate 255 and edit it to print white(not white but mask)
AlistairBean1906
Message 7 of 11 (6,405 Views)
11-08-2010 01:12 AM in reply to: jpw777
I believe you will get a similar effect (or possibly better) if you use RGB colours from the True Colour Tab. set each to 255
Now the out put isn't controlled by the CTB or STB file only by the colour you selected.
*Expert Elite*
Message 8 of 11 (6,387 Views)
11-08-2010 09:11 AM in reply to: AlistairBean1906
True color 255, 255, 255 is what I use.  It works right out with CTBs but if I want to use it with STBs, I still need to set the Layer to Normal so I can get the white effect (STBs don't care what color the entities are otherwise).
Member
Message 9 of 11 (5,048 Views)
10-02-2012 03:38 PM in reply to: jpw777
Like 3wood was saying you could make the furnature a block reference then create the wipeout within the reference as part of the block. That way, when you translate the block to another part of the page, the wipeout moves with it.
Member
Message 10 of 11 (5,046 Views)
10-02-2012 03:41 PM in reply to: bnearl
I've done this with just today with all of my equipment tags in my drawings, due to not having enough empty space in the background beside my exhaust fans.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
