AutoCAD 2010/2011/2012
Active Member
auto_2013
Message 1 of 6 (706 Views)
HELP! Placing a 3D Object raised on the surface of another 3D object
706 Views, 5 Replies
05-02-2012 07:12 AM
Hello!
I've already started using the AutoCad 3D. I got a question that I hope someone can help me out.
I am just wondering to know how to put a 3D object on top of the another 3D object in autocad"! E.g.,I want to put a 3d object of one leaf (raised 1") on top of the vase, so that the edges of the leaf are placed completely on the surface of the vase.
I extruded the leaf 1" first, then tried to copy it on a solid cylinder of a vase, but it didn't work!!! It seems to be simple, maybe not!
Would you please let me know whether the Autocad can handle such this thing! Looking forward to hearing from you soon.
Thanks in advance and best wishes,
Rihana
abipattern
Message 2 of 6 (693 Views)
Re: HELP! Placing a 3D Object raised on the surface of another 3D object
05-02-2012 11:59 AM in reply to: auto_2013
This is fairly easy. Having your object (vase) to place on, make scaled larger copy by the one inch, this will be part of the placed object (leaf), extrude the leaf design beyond this offset part and run interfere, uncheck delete interfere object. Then take the original object (vase) and union with the interference object,
Attached is a bug offset a sphere with a similar offset.
*Expert Elite*
JDMather
Message 3 of 6 (682 Views)
05-02-2012 01:50 PM in reply to: auto_2013
What you might want to do is Imprint and then thicken (or offset the face, whatever it is called in solidedit in AutoCAD).
Attach your file here for further instruction.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
Active Member
auto_2013
Message 4 of 6 (645 Views)
06-01-2012 11:24 AM in reply to: abipattern
Many thanks for your reply! This is exactly what I am looking for. I just missed "Having your object (vase) to place on, make scaled larger copy by the one inch, this will be part of the placed object (leaf),"
Can you explain it more! Please take a look at the dwg attached. Looking forward to hearing from you soon.
THANKS
abipattern
Message 5 of 6 (605 Views)
06-04-2012 07:03 AM in reply to: auto_2013
See attached. The vase contour is just an oversize the amount you want the raised potion to be. In this case I used one inch as you suggested.
Active Member
auto_2013
Message 6 of 6 (584 Views)
06-05-2012 02:21 PM in reply to: auto_2013
Many thanks! It was a big help!
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
