AutoCAD Forum
Grip edit after modifying a 3D solid
2 REPLIES 2
crepps
1069 Views, 2 Replies
If I create a 3D solid (Box, for example) and I add a hole through it, the triangular grips are removed from the solid.  Is there a way to edit a 3D solid and keep the grip edits after the fact?
Office Laptop specs:
- Inventor Professional 2012 (Autodesk Product Design Suite)
- Dell Precision M6600
- Intel i7-2960XM @ 2.70GHz
- 8GB RAM
- 128GB mSATA SSD (main)
- (2) 750GB drives (non-RAID)
- touchscreen display w/ pen
- Windows 7 Ultimate
Home Laptop specs:
- Dell XPS 17 (non-3D version)
- Intel i7 2nd gen
- 16GB RAM
- (2) 500GB drives (non-RAID)
- AutoCAD Mechanical 2008 (Retail License)
- entire Audodesk product line (Student Licenses)
- Google SketchUp 8 (Retail License)
- Blender
- Cinema 4D
- various other design software packages
Tags (2)
2 REPLIES 2
Patchy
in reply to: crepps
Hold down the CTRL key and click on the edge, but that won't give you corner grips.
That the way it is with autocad.
edwin.prakoso
in reply to: crepps
Your SOLIDHIST variable is 0. If you set it to 1, you can keep the original object history after boolean operation.
You still need to hold CTRL to pick the sub object.
Or you can set sub object selection filter for easier selection. Read about sub object selection filter here.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
”Boost
