AutoCAD 2010/2011/2012
hmsuunnittelu
Message 1 of 11 (5,180 Views)
Grid in layout view
5180 Views, 10 Replies
05-21-2010 06:00 AM
I received a drawing that has a layout with multiple mviews in it. There is a light grey grid showing in the layout, that I can't make disappear. Grid on / off command has no effect. Really it doesn't matter if the grid is showing, but it's so annoying! Creating a new layout would fix the problem, but is there an easier way to get rid of the grid?
*Dean Saadallah
Message 2 of 11 (5,180 Views)
Re: Grid in layout view
05-21-2010 06:09 AM in reply to: hmsuunnittelu
AUDIT or RECOVER commands to fix the file, see if that helps, or use SAVEAS
to create a new file, delete all private info and post the DWG file here.
Or just create a new layout as you noted.
Dean Saadallah
http://LTisACAD.blogspot.com
*Pro
Modman_4
Message 3 of 11 (5,180 Views)
05-21-2010 07:10 AM in reply to: hmsuunnittelu
...or write the whole thing off as a block. Or create a new drawning and copybase the entire contents of old into new...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
GrantsPirate
Message 4 of 11 (5,180 Views)
05-21-2010 07:13 AM in reply to: hmsuunnittelu
Make that VP current and then turn grid off.
hmsuunnittelu
Message 5 of 11 (5,161 Views)
06-22-2010 03:32 AM in reply to: GrantsPirate
Last time I just ended up creating a new layout, but this problem seems to come up repeatedly. It seems that if the layout has been created with the grid on in the model space, it will also show in the layout.
I don't know how to "make the VP current and then turn grid off", so further advice would be welcome.
Other suggestions would also be appreciated.
Valued Contributor
nikolap
Message 6 of 11 (5,141 Views)
06-22-2010 10:37 AM in reply to: hmsuunnittelu
Old school, no ribbon: Tools -> Drafting Settings -> Snap and Greed -> Greed style: uncheck Sheet/layout and, of course, press F7 for greed On/Off
hmsuunnittelu
Message 7 of 11 (5,114 Views)
06-23-2010 12:12 AM in reply to: nikolap
Changing drafting settings has no effect on the problem...
Product Support
Silvia.Menon
Message 8 of 11 (5,106 Views)
06-23-2010 01:22 AM in reply to: hmsuunnittelu
Double-click inside the viewport to make it active, and then press F7.
Any change?
Silvia
Silvia Menon
Autodesk Product Support
hmsuunnittelu
Message 9 of 11 (5,102 Views)
06-23-2010 01:35 AM in reply to: Silvia.Menon
Thank you so much! I don't know how I didn't think of something that simple.:smileyvery-happy:
New Member
eg07
Message 10 of 11 (3,898 Views)
10-24-2011 02:37 PM in reply to: hmsuunnittelu
Thanks a lot.. I was trying to figure out the same thing... your post was very helpfull!! 'Thumbs up'
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
