AutoCAD 2010/2011/2012
Valued Contributor
jneilon
Message 1 of 13 (335 Views)
Accepted Solution
Generate Roofs based on plines
335 Views, 12 Replies
12-10-2012 11:27 AM
Is there a way to generate a roof based from plines? Like this but without tracing? I need to generate multiple roofs at once with the same slope ect.
Thanks.
Valued Contributor
Patchy
Message 2 of 13 (326 Views)
Re: Generate Roofs based on plines
12-10-2012 12:24 PM in reply to: jneilon
Use this http://usa.autodesk.com/autocad-architecture/ you can
Not plain Autocad
Valued Contributor
jneilon
Message 3 of 13 (323 Views)
12-10-2012 12:30 PM in reply to: Patchy
I presume your pointing to AutoCAD architectures Create roof function?
I am using AutoCAD Architecture and the Roof create botton but the only way to generate the roof is by tracing the walls of a building. In my case I have a polyline that I would like to select then generate a roof.
Valued Contributor
Patchy
Message 4 of 13 (319 Views)
12-10-2012 12:34 PM in reply to: jneilon
*Expert Elite*
hmsilva
Message 5 of 13 (306 Views)
12-10-2012 01:52 PM in reply to: jneilon
jneilon,
attach a small dwg with a sample of buildings and roofs that you want.
Henrique
Valued Contributor
jneilon
Message 6 of 13 (301 Views)
12-10-2012 02:09 PM in reply to: hmsilva
 Henrique See attached file for the building outline. The roof I am after is a Hip roof. A more manual way of doing this is here http://www.youtube.com/watch?v=2OHx4a-3VBQ
I did not realize there was a Architecture forum I will ask there too.
*Expert Elite*
hmsilva
Message 7 of 13 (291 Views)
12-10-2012 04:15 PM in reply to: jneilon
jneilon,
attached is a dwg with roofs, and a lisp file, I wrote now, is minimally tested... I dont know if you usually use lisp files, if not, saved the file and load it with appload command, see the dwg, it also has some notes.
Hope that helps
Henrique
*Expert Elite*
dbroad
Message 8 of 13 (266 Views)
12-11-2012 05:12 AM in reply to: jneilon
A few reasons why you might not be able to get the roof conversion to work after looking at your file:
1)Your drawing units are in millimeters but your floor plans are only 12.5 units long.
2)Your polylines are old 2d polylines, not new so the system cannot recognize them.  Use CONVERTPOLY and then scale the plans up to make them true representations of the building size in millimeters.
Valued Contributor
jneilon
Message 9 of 13 (257 Views)
12-11-2012 06:21 AM in reply to: dbroad
Sorry the lines were exported from 3Dsmax I did not check them.
Valued Contributor
jneilon
Message 10 of 13 (250 Views)
12-11-2012 06:36 AM in reply to: hmsilva
Thanks Henrique,
This works, I will see if a colleage of mine can automate this more.. I was hoping acad's create roof command would just work based on splines that are already created instead of specifing them by retracing. I am working on 100+ houses I would hate to redraw all of them manually.
Edit: In the AutoCAD architecture forum showed me a way to use the roof command on lines. Now I just need to automate it.
Thanks again for the help
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
