AutoCAD 2010/2011/2012
Member
Message 1 of 9 (241 Views)
Accepted Solution
GROSOR LÍNEA / GROSOR LINE
241 Views, 8 Replies
09-14-2012 12:17 PM
En Español
Es una pregunta de un examen de test de un concurso-oposición... A ver si me podéis echar una mano porque yo no estoy de acuerdo con la corrección y necesito poder justificarlo para la reclamación¡¡¡¡
La pregunta era:
¿Cómo se denominan los distintos grosores de línea en Autocad?.
Muchas gracias, un saludo.
Alicia.
In English
At the first, sorry because I speak english very bad. I hope that you understand me.
It is a question of a test examination for a public job... Let's see if I can help out because I do not agree with the correction and I need to be able to justify the claim
The question was:
How are called different line thickness in Autocad?.
Thank you very much, greetings.
Alicia.
Valued Contributor
Message 2 of 9 (230 Views)
Re: GROSOR LÍNEA / GROSOR LINE
09-14-2012 12:38 PM in reply to: alicevama
lineweights are specific widths in inches or millimeters and can be set by color with ctb files or by layer/entity with stb files
Member
Message 3 of 9 (226 Views)
09-14-2012 12:51 PM in reply to: gwhite
Thank you gwhite¡¡¡¡
Buit, doesn´t exist a command that´s called Display Lineweights in Autocad??
I try to translate the answers:
- Correct answer for the examiner: Pens.
- Correct answe I think: Lineweihts (this command in spanish´s version is called GrosorLin).
Valued Contributor
Message 4 of 9 (218 Views)
09-14-2012 01:00 PM in reply to: alicevama
solamente marca "lineweight" en el command line y puede ver un dialog box con todo informacion - puede cambiar entre inches o milimeters
lo siento, mi espanol is malo
Member
Message 5 of 9 (214 Views)
09-14-2012 01:05 PM in reply to: gwhite
My englis is very bad too¡¡¡
- Correct answe I think: Lineweihts (this command in spanish´s version is called GrosorLin), because i think ctb files or stb files are plot styles, no?
Valued Contributor
Message 6 of 9 (200 Views)
09-14-2012 01:15 PM in reply to: alicevama
"pens" es arcaico - no tenemos "pens" en plotters hoy y quando vea el "properties dialog" se dice "lineweights", no "pens". Creo que ud. ere corecto.
Member
Message 7 of 9 (198 Views)
09-14-2012 01:20 PM in reply to: gwhite
ok¡¡
I think that i am wrong wiht the translation¡¡¡ jajajaja
How you called " Pen Numbers and Virtual Pens in Plot Style Tables"?
Valued Contributor
Message 8 of 9 (185 Views)
09-14-2012 01:30 PM in reply to: alicevama
they reflect back to when you had to use a different physical ink pen for each line weight - no idea what they are used for now except to keep some oldtimers happy with their nomenclature - I leave them set at automatic and never bother with them
que reflejan de nuevo a cuando tenías que usar una pluma de tinta diferente física para cada grosor de línea - ni idea de lo que están acostumbrados, por ahora, excepto para mantener algunos veteranos feliz con su nomenclatura - dejo establecido en automático y no preocuparse de ellos
Thank you Google
Member
Message 9 of 9 (181 Views)
09-14-2012 01:36 PM in reply to: gwhite
I am using also¡¡¡¡
Thanks you for all¡¡¡ I hope to get lucky with the claim¡¡¡
greetings...
Ali
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
