AutoCAD 2010/2011/2012
Member
apec_engineering
Message 1 of 5 (3,454 Views)
Function keys customization
3454 Views, 4 Replies
06-02-2011 01:01 PM
Can anybody help?
Using the CUI editor I have tried to customize the function keys in Autocad 2012.
The default for each of the keys is noted here:
F4
Command:  <3DOsnap on>
F6
Command:  <Dynamic UCS on>
In Autocad 2006 I have the keys customized to do the following:
F4
Macro:  '_zoom_p
F6
Macro:  _cen
Can anybody help?
Patchy
Message 2 of 5 (3,444 Views)
Re: Function keys customization
06-02-2011 01:34 PM in reply to: apec_engineering
Command CUI, see image (it's from 2010, for 2012 same steps)
Member
apec_engineering
Message 3 of 5 (3,430 Views)
06-02-2011 01:54 PM in reply to: Patchy
My screen snip from Autocad 2012 cui is attached.
Patchy
Message 4 of 5 (3,421 Views)
06-02-2011 02:07 PM in reply to: apec_engineering
That comes with Autocad, it's temp. override keys, don't mess with it. When you do as I showed you, drop it at the "SHORTCUT KEYS"  it will work.
Member
apec_engineering
Message 5 of 5 (3,402 Views)
06-02-2011 02:26 PM in reply to: Patchy
Fine it worked now.
Drag and drop to the Shortcut Keys section.
Don't click on the 3 dots button.
Just type the key combination into the Access Key(s) box (i.e. F6 or F4)
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
