Dear Friend,
I have deleted all elements in file but still it show huge file size 10.6 MB. how to make it samll size after deledting all drawings from a file.
Regards
Pritam Gupta
you can try:
- command _WBLOCK and seelect only the objects you need
- command _PURGE to free up definitions not needed (like block definitions, textstyles, dimstyles, linetypes, ...)
- if available you can try command _-EXPORTTOAUTOCAD to get rid of AEC-specific proxies.
If nothing helps upload the drawing to a free server and show us the link to that drawing so we can look into it.
Good luck, - alfred -
One more thing to look for....microstation linetype data embedded in the drawing. See http://cadpanacea.com/node/411 for more info.
If you can't share the drawing with us here, get SuperPurge and you should be able to find it yourself.
Autodesk released the AutoCAD® DGN Hotfix for AutoCAD 2012 last week. This may resolve the problem.
-Volker
Please let us know if your questions have been answered by selecting, "Accept as Solution"
Volker C.
SR Technical Support Specialist, KDE
Autodesk Customer Council | Only One AutoCAD | AutoCAD Blog
@pendean wrote:
Start LINETYPE command: is ther a long list of linetypes?
If that is referring the microstation linetype bloat problem, then FWIW, I have seen a couple of polluted drawings that did not show the linetypes as available, but did contain all the background garbage that bloats the drawing.
