AutoCAD 2010/2011/2012
New Member
kristen.muse
Message 1 of 7 (965 Views)
FIlter Command
965 Views, 6 Replies
07-26-2011 07:28 AM
I am posting this for a co-worker.  She is trying to use the filter command, and according to her, you use to able to apply the filter to only a certain area within the drawing.  This use to work in previous versions of AutoCAD, however we cannot figure out how this works in AutoCAD 2011.  Any suggestions?  Thanks!
*Pro
nestly
Message 2 of 7 (954 Views)
Re: FIlter Command
07-26-2011 09:12 AM in reply to: kristen.muse
I believe FILTER works the same in 2011 as it did in AutoCAD2005, at least it does for me.
After clicking "Apply" the command line prompts "Select Objects".... simply window the area to be filtered and press <Enter>
You may want to try the newer QSELECT command instead of FILTER however.  It's always available via the standard right-click menu, and is more intuitive IMO.
*Expert Elite*
Patchy
Message 3 of 7 (943 Views)
Re: FIlter Command
07-26-2011 09:19 AM in reply to: nestly
I think Qselect doesn't let you use window to filter out what you want, may be that is why the question got brought up :smileytongue:
*Pro
nestly
Message 4 of 7 (939 Views)
Re: FIlter Command
07-26-2011 09:23 AM in reply to: Patchy
Patchy wrote:
I think Qselect doesn't let you use window to filter out what you want,...
You can window the selection before starting QSELECT, otherwise  use "Apply to" to create a windowed selection set afterward....
*Expert Elite*
Patchy
Message 5 of 7 (928 Views)
Re: FIlter Command
07-26-2011 09:32 AM in reply to: nestly
Hot dog, Mine always grayed out, until I clicked the bottom check box.:smileyvery-happy:
I owe you 1
*Expert Elite*
Murph
Message 6 of 7 (921 Views)
Re: FIlter Command
07-26-2011 10:08 AM in reply to: nestly
Except for filtering on block attributtes, somewhere along the way that got broken in the filter. Qselect works for that now. : (
Murph
Supportting the troops daily.
New Member
EMAD1pk
Message 7 of 7 (507 Views)
Re: FIlter Command
08-30-2013 11:45 PM in reply to: kristen.muse
hi...well i was also searching for this command to be used in the way i needed but i found other way which might be helpfull for u also....first select the object under ur consideration then right click and `select similar` and everything similar to that thing will be selected..... :smileyvery-happy:
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
