AutoCAD 2010/2011/2012
Member
spierce82
Message 1 of 6 (4,363 Views)
FATAL ERROR: Unhandled e0434f4dh Exception at
4363 Views, 5 Replies
11-12-2010 05:03 AM
I had a FATAL ERROR: Unhandled e0434f4dh and after researching it for about in hour I stumbled upon this easy fix.
Running 2010 AutoCad on Windows 7 and searched for "reg" I noticed a "cc_20080624_1633.reg" file, double clicked it and added what it wanted and wahla AutoCad is back and working again.
Now if someone could explain what happened that would be great otherwise maybe I should play the lottery today because it was just dumb luck that it worked as my knowledge of all this is limited.
Member
spierce82
Message 2 of 6 (4,362 Views)
Re: FATAL ERROR: Unhandled e0434f4dh Exception at
11-12-2010 05:06 AM in reply to: spierce82
I forgot to mention that I had reinstalled the Microsoft Framework 4.0 extended. After doing this AutoCad 2010 still didnt work but it could of done something.
New Member
Message 3 of 6 (4,193 Views)
11-19-2010 06:25 AM in reply to: spierce82
This regfile You are reffering to. Where is it located?
Member
spierce82
Message 4 of 6 (4,188 Views)
11-19-2010 06:47 AM in reply to: spierce82
Its in the user directory;
C:\users\my profile name\documents\
Ownership of the file is the IT guru, wierd...
Quite possibly a pemissions issue??
Active Contributor
Message 5 of 6 (2,961 Views)
05-23-2011 08:16 AM in reply to: spierce82
Hi there,
What was in the reg file? Can you send a copy? It would be interesting to see exactly what it did to the system - we are experiencing similar issues and a repair of the .net framework has not fixed it.
Jim
Member
Message 6 of 6 (1,304 Views)
06-07-2012 05:43 AM in reply to: spierce82
The file they are running looks like a backup from a cclean registry clean.   The programs must have removed something that AutoCAD needed and putting those values back in by running the reg file fixed the problem.  Would be interesting to see what values CClean  removed
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
