I have a brand new workstation and only on certain files it will say FATAL ERROR: Cannot write to undo file (probably disk full) when ever I save. I have tried cleaning out the TEMP file, turning off the Undo function, auditing the file and its xrefs, and recovering the file. It was a file that was on the server, but I have pulled it to my local machine and I have also increased the amount of virtural memory avaiable.
Can you define what that means to you?
If you open Windows Explorer, go to the address bar, type in %temp% - this is where the temp files are probably going, unless you have specifically changed it.
