Can anyone find an error in the following .pat file? I believe the coordinates are correct, it just won't read in AutoCAD 2011.
Thank you in advance!
Solved by Alfred.NESWADBA. Go to Solution.
You have those two lines in your PAT:
0, 0,0, 0, 0, 10, -20, 20
90, 0,0, 0, 0, 30, -20
And you need at least one deltaX or deltaY, in both lines both of those values are 0.
The rest here works:
90, 0,0, 0,10, 10, -20, 20
90, 0,0, 0,20, -10, 30,-10
90, 0,0, 0,30, 20, -20, 10
90, 0,0, 0,40, -20, 30
0, 0,0, 0,10, 30, -20
0, 0,0, 0,20, -20, 30
0, 0,0, 0,40, -10, 30,-10
- alfred -
