AutoCAD 2010/2011/2012
Member
timothy.connell
Message 1 of 6 (626 Views)
Dynamic Block Rotate Grip doesn't stay put
626 Views, 5 Replies
03-26-2010 01:25 PM
Can anyone take a look at this drawing and tell me why the dynamic block rotate grip won't stay attached to the endpoint of a line? It will stay attached until I change other grips in the part, then the round grip moves away from the end of the line and now I have no way to properly align my "ground plane". Please see the attached drawing.
Valued Contributor
IanH5033
Message 2 of 6 (626 Views)
Re: Dynamic Block Rotate Grip doesn't stay put
03-27-2010 05:53 AM in reply to: timothy.connell
Can you check your posted drawing please - I have just converted it back to 2007 format to take a look and it only contains an ordinary block not a dynamic block.
Many thanks
Ian
Member
timothy.connell
Message 3 of 6 (626 Views)
03-29-2010 11:16 AM in reply to: timothy.connell
Hmm, dynamic in my drawing. I'll re-attach just in case.
*Kate M
Message 4 of 6 (626 Views)
03-29-2010 12:18 PM in reply to: timothy.connell
It won't behave properly in 2009 & earlier because it's got constraints.
And I'm not sure if this will solve your problem, but is there a reason
you're using a rotation action instead of an angular constraint?
Kate Morrical
AutoCAD LT Technical Marketing Manager
http://blogs.autodesk.com/ltunlimited
wrote in message
news:6362799@discussion.autodesk.com...
Member
timothy.connell
Message 5 of 6 (626 Views)
03-29-2010 12:39 PM in reply to: timothy.connell
angle constraint wont let me set it to 0 degrees.
Distinguished Contributor
mmcmanus
Message 6 of 6 (626 Views)
03-31-2010 08:52 AM in reply to: timothy.connell
I see what you mean about the dot not lining up. I opened it in the block editor, didn't change anything and then closed the block editor and it seems to line up fine now. I moved it around a few times and it still worked but I don't know why.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
