AutoCAD 2010/2011/2012
Active Contributor
Message 1 of 5 (464 Views)
Accepted Solution
Duplicate Attribute (echo)
464 Views, 4 Replies
11-16-2012 02:25 AM
I have a drawing template (block) where the drawing number is displayed in two locations (attributes). The same value has to be entered in both attributes.
Is there any way of "echoing" the data from one attribute to other attributes (or text objects)?
*Expert Elite*
Alfred.NESWADBA
Message 2 of 5 (455 Views)
Re: Duplicate Attribute (echo)
11-16-2012 05:21 AM in reply to: thebeesnees
using fields can do that (>>>details<<<).
Check the attached drawing with one sample block inserted. Change it's attribute "ORIG" and after that do a _REGEN.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
Message 3 of 5 (449 Views)
11-16-2012 06:08 AM in reply to: Alfred.NESWADBA
Almost perfect.
Only minor issue is that the second attribute (COPY) can be overwritten accidentally. Would be ideal if the second attribute could be hidden or protected although I don't think it is possible.
Does the job though, thanks for your help.
Active Contributor
Message 4 of 5 (89 Views)
02-13-2014 11:53 AM in reply to: Alfred.NESWADBA
Ok, nice example. But how did you do it?
Active Contributor
Message 5 of 5 (82 Views)
02-13-2014 03:17 PM in reply to: cvc-it-mb
Found it... I was unclear on the step-by-step.
  1. Create a single attribute.
  2. Create an MText object or another Attribute.
  3. Within the editor, open the shortcut menu (right-click in edit-box) and select insert field.
  4. Field Category: Objects
  5. Field Names: Object.
  6. For Object Type, click the select object button, then select the attribute from your drawing.
  7. Select Property: Value.
Jim
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
