AutoCAD Forum
Drawing regeneration
3 REPLIES 3
tony
499 Views, 3 Replies
I am using Autocad 2012 and are trying to get this command "LAYOUTREGENCTL" to stay set to either 1 or 2. I can set it through the options dialogue or from the command line but it changes back to 0 instantly
Any suggestions out there? I am running Autocad Structural Detailing on top of Autocad, is it possible this is preventing the change?
<script id="overlay_tmpl" type="text/html">// <div id="<%= overlayId %>" class="_mp3rocket_overlay_style" style="left: <%= overlayLeft %>; top: <%= overlayTop %>; width: <%= overlayWidth %>; height: <%= overlayHeight %>"></div> // </script>
3 REPLIES 3
rkmcswain
in reply to: tony
It changes back instantly? Meaning that it never really changes to what you are manually setting it to?
Either there is a reactor loaded that is doing this, or this is some feature of your add-on product.
R.K. McSwain     | CADpanacea | on twitter
tony
in reply to: rkmcswain
Thanks for the reply
What is a reactor
*Tony Gibbs* /, Delta WA Services/
Tel: (08) 64654400 | Mobile: 0408408200
rkmcswain
in reply to: tony
Essentially, it's a piece of code running all the time that monitors things (whatever you tell it too)
So there could be a reactor loaded that is monitoring that system variable, and as soon as it changes, the reactor fires some code to change it back.
It's a long shot, but possible.
Here is an example of a reactor that alerts you when your autosave setting is changed.
”Boost
