AutoCAD 2010/2011/2012
Valued Mentor
KLYPHY
Message 1 of 10 (283 Views)
Drawing from Hatches
283 Views, 9 Replies
01-09-2013 07:46 AM
I may be imaging it. I started with AutoCAD 9. That means I'm my 60s now. I forget things now.
But I thought that until recently, that I could draw a line from parts of a hatch.
I could draw a line perpendicular to a hatch line.
Or, I could draw a line from an intersection of hatch lines.
Well, I sure can't now.
Did I change a setting?
Or have I imagined being able to do such?
Any help?
Read Ya Later -KLYPH
Valued Contributor
Patchy
Message 2 of 10 (281 Views)
Re: Drawing from Hatches
01-09-2013 08:05 AM in reply to: KLYPHY
You still can, in OPTIONS
Valued Mentor
KLYPHY
Message 3 of 10 (273 Views)
01-09-2013 08:10 AM in reply to: KLYPHY
Yesterday, I spent nearly an hour exploring "Options".
There are many settings.
I messed things up trying different ones.
So, I still don't have any idea where in Options to go.
Valued Contributor
Patchy
Message 4 of 10 (268 Views)
01-09-2013 08:14 AM in reply to: KLYPHY
You can change the variable OSOPTIONS
0
Object snaps operate on hatch objects, and on geometry with negative Z values when using a dynamic UCS
1
Object snaps ignore hatch objects
2
Object snaps ignore geometry with negative Z values during use of a dynamic UCS
Valued Mentor
KLYPHY
Message 5 of 10 (261 Views)
01-09-2013 08:22 AM in reply to: Patchy
Thanks. OSOPTIONS had been set to "3".
Setting it back to "0" cured the problem.
So, I now know of OSOPTIONS, but, I still can't find it in OPTIONS.
Valued Contributor
Patchy
Message 6 of 10 (255 Views)
01-09-2013 08:30 AM in reply to: KLYPHY
Options, Drafting Tab, uncheck the box.
Valued Mentor
KLYPHY
Message 7 of 10 (248 Views)
01-09-2013 08:35 AM in reply to: Patchy
Thanks again.
Now it seems so obvious, but I just never "saw" that button.
But now, for the better, I now know about OSOPTIONS and I can write a lisp to turn the settings "on" or "off".
Again, thanks for your help.
Valued Mentor
KLYPHY
Message 8 of 10 (196 Views)
01-11-2013 08:09 AM in reply to: KLYPHY
So, I need further help.
I keep getting an e-mail from AutoDESK asking if my question has been solved.
If it has been solved, I'm instructed click "here".
I click on it and it takes back to the original question display.
I cannot find out where to click to indicate the question has been solved.
Any help out there? -KLYPH
Patchy
Message 9 of 10 (177 Views)
01-11-2013 08:28 AM in reply to: KLYPHY
It depends on the Browser you use.
Firefox shows but Google Chrome won't
Valued Mentor
KLYPHY
Message 10 of 10 (147 Views)
01-14-2013 06:46 AM in reply to: KLYPHY
Thanks for your reply. That is our problem; we're using Google Chrome.
I'll check with our Tech Guy.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
