Hello everybody
I try to open a drawing file and each time I try, I get the response that the drawing file is not valid.
Can anybody help me to open this drawing? It is attached to this message. I have no temp file to recover unfortunately.
Thanks in advance!
Ps. you can find the drawing here http://we.tl/uo8QK0SDF9
sorry to say, but I get the same result, so it seems to be really defect..
Functions like _AUDIT or Map3D-DrawingQuery (which helps in some similar cases) did not help.
At least one of the packages I tried gave the message "unexpected fileend" so I guess if you have transfered it by mail or by download the transfer was interrupted.
The chance you have: redownload if you have the option, if the file was save on your workstation you might try to use the BAK file or at least take the DWG from a backup.
Sorry, - alfred -
