AutoCAD 2010/2011/2012
Valued Contributor
tstorzuk
Message 1 of 7 (1,858 Views)
Drawing a line from 0,0,0
1858 Views, 6 Replies
07-09-2012 01:14 PM
A little help please,
We have a new PC set up, and the user is trying to draw a line, starting from point 0,0,0. AutoCAD won't let him draw a line from that coordinate.
How do we get AutoCAD to draw from the BASE cooridinate? Is there a new switch that's messing this up?
Thanks in advance.
pendean
Message 2 of 7 (1,850 Views)
Re: Drawing a line from 0,0,0
07-09-2012 01:41 PM in reply to: tstorzuk
What does "won't let him' mean to the rest of us: is there an error message? or an additional prompt at the command line?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
EgoonS
Message 3 of 7 (1,846 Views)
07-09-2012 01:45 PM in reply to: tstorzuk
press F6 or F12, i think that causes cordinates to disable.
Valued Contributor
tstorzuk
Message 4 of 7 (1,837 Views)
07-09-2012 02:04 PM in reply to: pendean
These are the prompts that I get;
LINE
Specify first point: 500,500,0
Specify next point or [Undo]: 0,0,0
Zero length line created at (500,500,0)
Specify next point or [Undo];
JDMather
Message 5 of 7 (1,833 Views)
07-09-2012 02:11 PM in reply to: tstorzuk
Try #0,0,0 for second point entry and see if it works.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015 64-bit
pendean
Message 6 of 7 (1,819 Views)
07-09-2012 02:36 PM in reply to: JDMather
Use # for both sets coordinates you want your line to be between, not just the last one: see if your issue goes away.
*Pro
nestly
Message 7 of 7 (1,802 Views)
07-09-2012 05:25 PM in reply to: tstorzuk
The default behavior is controlled by DYNPICOORDS
DSETTINGS > Dynamic Input > Settings > For second or next point, default to:
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
