AutoCAD 2010/2011/2012
Valued Contributor
thanhtike.myn
Message 1 of 4 (425 Views)
Drawing Units
425 Views, 3 Replies
05-02-2012 07:40 PM
Hi all,
I received a dwg file which unit have set up to Meters. So whenever i measure or draw the lines it displayed the unit in Meters. I want to know how to change the unit to Millimeters so that when i draw a line in 100 units...it should be 100mm, not 100m. Any idea pls.
Thanks.
Thanhtike
pendean
Message 2 of 4 (424 Views)
Re: Drawing Units
05-02-2012 07:47 PM in reply to: thanhtike.myn
-DWGUNITS command (there is a dash in the command name)
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Valued Contributor
thanhtike.myn
Message 3 of 4 (417 Views)
Re: Drawing Units
05-02-2012 08:11 PM in reply to: pendean
hi,
i tried with that command (-DWGUNITS) but the units still displaying in Meters.
Attached the screen short for the command procedure i tried.
thanks.
Thanhtike
Patchy
Message 4 of 4 (402 Views)
Re: Drawing Units
05-02-2012 08:53 PM in reply to: thanhtike.myn
How did you measure or draw the lines ??????  Let's say your UNITS is decimal to be used with metric.
There is list, distance and there is dimension command, list and distance will not tell you it is meter or milimeter, dimensioning shows m or mm is how you chose it, you must scale the drawing to get it to show the unit you prefer.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
