Having difficulty installing AUTOCAD 2012..32bit I am having an error says : Error applying transforms. Verify that the specified transform paths are valid. I am using Windows Vista... Thanks in advance for you help and instructions
can you upload a screenshot when this message appear and upload it?
Never heard that yet (and also don't find messages in www).
And just to make sure:
- you do install AutoCAD 2012 and not AutoCAD Map3D 2012?
- you are logged in as administrator?
- you have turned off your antivirus software?
- you do install onto your local harddisk? (not a USB-stick/-drive or so)
- alfred -
Hi alfred tnx 4 the reply
heres the screenshot of the error i am getting
I am installing AUTOCAD MEP 2012.. And im also logged in as the Admin. My anti-virus is off, I am installing it directly on my Hard drive
if you tried to install from DVD then copy the content of the DVD to a local temp directory and start the installation from that position.
If you tried to install from a downloaded file, then redownload it, might be a defect download.
As the second error message raises based on the Inventor-Fusion install you might also try to disable the installation of Inventor Fusion and try to get the base product installed first without this option.
If the user account you are currently in is your default user account then try to create a new user-account to your windows (havin admin permissions) just to make sure that there is no conflict with the current user profile.
Good luck, - alfred -
Hi
I alredy create the another user acc and copy the content to local temp directory.....but still same error
and the other suggestions? (redownload, disable Inventor Fusion, ..)?
- alfred -
and have you tried to redownload the package?
Inventor Fusion (in the installation of AutoCAD, not MEP) has a checkbox in the list of products that will be installed, sorry if that is not so for MEP.
- alfred -
