AutoCAD 2010/2011/2012
MartinBrown
Message 1 of 3 (194 Views)
Accepted Solution
Dimension tool
194 Views, 2 Replies
04-26-2012 02:23 AM
Can you use the dimension tool but enter your own data instead of it entering the measured data?
Martin
*Expert Elite*
Alfred.NESWADBA
Message 2 of 3 (191 Views)
Re: Dimension tool
04-26-2012 02:37 AM in reply to: MartinBrown
Yes, you have the option to overwrite the measured value, look e.g. into the property-windows while the dimension is selected. Be careful without the special case of "<>" in the overriding text you loose the option that the value updates when the dimension get's stretched!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Distinguished Contributor
greg.battin
Message 3 of 3 (106 Views)
Re: Dimension tool
05-06-2012 07:16 PM in reply to: MartinBrown
The easiest way to avoid snapping to the wrong end-point is to use the option to select an object when placing the dimenion. Notice in the command line that it asks you to "specify first extension line origin" and then it also gives you the option to hit enter so that you can "<select object>"
Simply hit <enter> and select the line segment (or object) and then place the dimension. No longer will you have to pick 2 points and hope that you snapped to the correct osnap...
~Greg
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
