AutoCAD 2010/2011/2012
Message 1 of 9 (1,099 Views)
Dimension Input Prompt
1099 Views, 8 Replies
08-15-2011 11:23 AM
What or where is the setting to change the dimension value input to automatic rather than accepting the default everytime I put a dimension in?  I don't want to be prompted for input.
Bo
Valued Contributor
Message 2 of 9 (1,085 Views)
Re: Dimension Input Prompt
08-15-2011 11:04 PM in reply to: bobarket
Dimension Style Manager -> Modify -> Primary Units -> Measurement scale -> Scale factor: ... (write factor)
Message 3 of 9 (1,068 Views)
08-16-2011 08:44 AM in reply to: nikolap
Appreciate the response but I'm not sure this was the solution.  Anyway, I tried it and nothing changed.  After I select a location for my dimension I'm asked to accept the default value or type in my own value.  I don't want this prompt.  I only want to place the dimension after I select a location without being prompted.  Sorry if I'm not getting it.
Bo
New Member
ronaldalau
Message 4 of 9 (993 Views)
11-14-2011 01:46 PM in reply to: bobarket
Just found it:
Autocad Mechanical 2012
Options, AM:smileyfrustrated:tandards tab
right click 'Dimension' click settings to get to 'Dimension Settings' dialog.
Down at bottom, "Display dimention text editor:"  Choose 'Only on Demand' in dropdown list.
Hope this helps.
Picture is related.
Message 5 of 9 (986 Views)
11-14-2011 02:07 PM in reply to: ronaldalau
sorry but i don't have AM standards tab.  is there a command line entry to get to the dimensions settings dialog
Message 6 of 9 (975 Views)
11-14-2011 04:28 PM in reply to: bobarket
You have to hit "ENTER" to accept the default value and complete the command.
I don't think there is any other way around that. nikolap's reply is worth taking a second look.
Autodesk AutoCAD Map 3D 2015
Windows 7 Professional
Service Pack 1
Intel(R) Core(TM) i5-4430 CPU @ 3.00 GHz
8.00 GB RAM
Distinguished Contributor
JIMDONALDSON6595
Message 7 of 9 (959 Views)
11-15-2011 07:20 AM in reply to: bobarket
On my 2012 dimensions, It does not prompt for a location. But I cannot figure out which variable is controlling this. I am attaching a DWG with my settings and examples
Jim
JIMDONALDSON6595
Message 8 of 9 (953 Views)
11-15-2011 07:31 AM in reply to: JIMDONALDSON6595
Sorry I meant it does not prompt for text after location.
Jim
New Member
Message 9 of 9 (715 Views)
10-11-2012 09:37 AM in reply to: bobarket
Type in Command Line: [dimassoc ] set value to [2]
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
