AutoCAD 2010/2011/2012
TonyKiertianis
Message 1 of 8 (873 Views)
Diameter symbol displays small
873 Views, 7 Replies
06-10-2011 07:28 AM
Anyone know of a fix for the diameter symbol? When using the diameter dimensioning function the diamter symbol displays small. Presently using AutoCAD 2011 and dimensioning in accordance with ASME Y14.5M which states the size of the circle for the diameter symbol is equal to your text height. What is happening is when the symbol appears the line that goes through the circle is equal to the text height instead of the circle which in turn makes the circle smaller. We can fix this by editing every time but hoping someone knows of a fix or educate me on something I am missing. We have to abide by the ASME spec so the smaller symbol is not acceptable. Thanks
*Expert Elite*
Patchy
Message 2 of 8 (847 Views)
Re: Diameter symbol displays small
06-10-2011 08:47 AM in reply to: TonyKiertianis
If they don't call for specific font, use Truetype font will solve it.
TonyKiertianis
Message 3 of 8 (829 Views)
06-10-2011 10:04 AM in reply to: Patchy
romans has always been choice of font and now combined with gdt font. I tried using the romans and gdt ttf fonts but the dimension including the diameter symbol look bold. Do you get the same result? Thanks
*Expert Elite*
Patchy
Message 4 of 8 (793 Views)
06-10-2011 11:14 AM in reply to: TonyKiertianis
Autodesk changed something, in 2008 it shows full diam. symbol. When open with 2010, the symbol got smaller.
I thought the font got changed in 2010 so I used old 2008 font, NO LUCK.
Will dig up the variable, if there is one.
TonyKiertianis
Message 5 of 8 (742 Views)
06-13-2011 04:10 AM in reply to: Patchy
The 1997 romans font file works if you can get a hold of it. Question is, how long will this file continue to work? We are trying to resolve this now before it gets too late as we have encountered other problems as well when opening legacy data to revise drawings where special characters (counterbore, down arrow, countersink etc) come in as question marks! I did post this problem as well. Everytime the company upgrades to a newer version of AutoCAD (since R13) we have always had this same problem but like I have said the 1997 romans font file cures it, for now! curious why the 1997 font file works and no others?
TonyKiertianis
Message 6 of 8 (717 Views)
06-13-2011 05:47 AM in reply to: TonyKiertianis
Trying to add attachment but having no luck?
*Expert Elite*
Patchy
Message 7 of 8 (693 Views)
06-13-2011 07:10 AM in reply to: TonyKiertianis
Certain files you can not attach, chage its extension to .txt , then it will let you.
TonyKiertianis
Message 8 of 8 (655 Views)
06-14-2011 04:59 AM in reply to: Patchy
I have tried txt, jpg, pdf, doc nothing works.....keep me informed on any solution with the symbols. Thanks
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
