AutoCAD 2010/2011/2012
Valued Contributor
thanhtike.myn
Message 1 of 4 (254 Views)
Delete Key
254 Views, 3 Replies
05-21-2012 06:21 PM
Hi all,
i'm encountering disable of Delete key. Normally i use "Delete" key to erase object after it is selected. Since yesterday i can't use that key anymore. So pls let me know how to check the setting. I'm sure its not keybord's issue coz i can still use the key in other program(Excel & Word).
Thank you in advance.
Thanhtike
Patchy
Message 2 of 4 (251 Views)
Re: Delete Key
05-21-2012 07:22 PM in reply to: thanhtike.myn
did you change PICKFIRST variable from 1 to zero?
Valued Contributor
thanhtike.myn
Message 3 of 4 (248 Views)
Re: Delete Key
05-21-2012 07:46 PM in reply to: Patchy
i think i didn't ...so tat variable should be "1" ? now i checked its "0"
And after i selected the object i can activate any command rite? now i cannot ...though i have selected the object it still ask me to select obj again. why?
And after i selected the object i can see the properties command in the shorcut menu ...now tat command and some are missing...i think i accidentally changed the setting and i m not sure what i did. I suspect one setting should related to these problems.
please give me the idea.
thanks.
Valued Contributor
thanhtike.myn
Message 4 of 4 (236 Views)
Re: Delete Key
05-22-2012 01:44 AM in reply to: thanhtike.myn
yup...because of that variable .
thanks alot.
Thanhtike
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
