AutoCAD 2010/2011/2012
Valued Contributor
Message 1 of 6 (807 Views)
Default scale factor
807 Views, 5 Replies
01-07-2011 04:45 PM
The scale command used to give the last used scale factor as a default - handy.  Now though it does not - anyone have any ideas how I can remedy this?
Valued Mentor
Message 2 of 6 (791 Views)
Re: Default scale factor
01-07-2011 08:00 PM in reply to: TickleMeElmo
Do you mean the scale command or the dimscale command? The scale command requests the user to select the object who then has the opportunity to scale the object(s) as needed. In the 27 years I've been using autocad, I've never seen what you describe with the dimscale command. The dimscale factor has always been 1" (for architectural) for new dwgs, and the only time it would not be was when opening a previous dwg
Valued Contributor
Message 3 of 6 (789 Views)
01-07-2011 08:19 PM in reply to: wengle
I meant Scale command as originally posted - I think it was changed behaviour in 2010 (or maybe 2011)?.  e.g. if I scale object(s) by 3.7, the next time the scale command is used the default scale factor is 3.7.   I'm almost certain I'm not imagining that.....if I am though Autodesk should implement it - any default beats no default.
*Expert Elite*
Murph
Message 4 of 6 (762 Views)
01-08-2011 05:38 AM in reply to: TickleMeElmo
Just so you don't feel crazy yes it did change in 2011. I don't know how to get it back if you can. :smileyhappy:
Murph
Supportting the troops daily.
Valued Mentor
Message 5 of 6 (741 Views)
01-08-2011 11:25 AM in reply to: TickleMeElmo
Okay - but it should not act like that. Do a Repair via the Control Panel. I've NEVER had that happen.
New Member
Message 6 of 6 (287 Views)
04-26-2011 02:14 PM in reply to: TickleMeElmo
Has anyone found out how to fix this! It's minor but annoying, why would they remove the scale factor display? Incidentally, even though the previous scale factor doesn't display, it is still used if you hit enter.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
