AutoCAD 2010/2011/2012
Active Contributor
russ1980
Message 11 of 18 (1,346 Views)
Re: DWG to PDF images not showing up
07-08-2011 01:19 AM in reply to: BarbM
hi Barb,
when you say converting from model space to paper space, what are you doing?
Have you got the viewport set up, and scaled appropriately?
russ.
Active Contributor
russ1980
Message 12 of 18 (1,344 Views)
07-08-2011 01:22 AM in reply to: cadman450
ah, the "Attempting to cancel" problem, not one ive ever found a proper solution for, we get it quite a lot, as i said exportpdf worked for us, sorry it hasnt solved your issue, I've never worked with ECW or SID files.
Hoping you find a solution.
New Member
BarbM
Message 13 of 18 (1,340 Views)
07-08-2011 04:20 AM in reply to: russ1980
Hi Russ
Thank you for your reply.  I finally figured out.  I checked my layer manager and the layer I was using to draw showed up as a non-plottable layer.  I went back and changed all my drawing to the correct layer and was able to save my drawing as a PDF>
cadman450
Message 14 of 18 (1,333 Views)
07-08-2011 07:15 AM in reply to: BarbM
unlike BarbM, having the image on the correct layer is not my issue unfortunately (I wish it was cause I could fix that).
I have been in contact with Autodesk Support, they want a sample drawing to see if they can reproduce the same problem, they should be able to figure it out after which I'll post a reply.
New Member
ColtnCrittenden
Message 15 of 18 (876 Views)
12-05-2012 02:07 PM in reply to: cadman450
I too am having issues with Civil 2012. Mine is the line work. It is covered by the sid image which is connected through the FDO. I've wasted several days and countless sheets of paper trying to find something. I've tried all of the RASTER___ commands and the slider. I've tried sending objects to the back and bringing them to the front. My images plot just fine nice USDA images all nice and crisp and in color. Go to find the line work, the actual meat n tators of the plan. NOTHING! I give up. I've cursed you long enough today Civil '12. :smileymad:
Colten
Architectural & Civil Drafting Tech
2nd year "noob"
*Expert Elite*
JGerth
Message 16 of 18 (871 Views)
12-05-2012 02:40 PM in reply to: ColtnCrittenden
Well, if you are connecting to a MrSID with FDO, then only the Map Workspace Display manager will change it. It's not a 'raster' any more, just an FDO.
You may find it simpler to use the Map Image Insert tool to place it as a georeferenced Raster - then it will be an Acad Raster Image, and you can fade it and change display order with Acad commands.
New Member
ssorensen
Message 17 of 18 (867 Views)
12-05-2012 03:18 PM in reply to: ColtnCrittenden
I still have my issue, never did figure it out.
New Member
jkraehling
Message 18 of 18 (741 Views)
02-12-2013 08:00 AM in reply to: cadman450
Try changing the Grphics quality to Low or Monochrome. that worked for us. :smileyhappy:
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
