A command that I am using frequently is "Pedit", to convert a line to a polyline. I have added it to a custom toolbar but it is just not completing the command. Here is the command macro I'm using:
^C^Cpedit \ j;
Solved by steve216586. Go to Solution.
Try this to join multiple lines and arc into a Pline in one selection operation:
^C^C-PEDIT;M;;Y;J;;;
Try this:
^C^C_PEDIT;\Y;;^P
You could always build PEDITACCEPT=1 into the macro...and you could probably shorten PEDIT to PE
If echoes and prompts from item input are turned off, a ^P in the item turns them off.
LeeMac's Polyline Join lisp is all I ever use. With one click, it automatically converts anything in the selection that can be converted into a polyine into a polyline, an then joins together all segments that can be joined. Works regardless of whether the selection is create first, or after starting the lisp.
I used to use that same lisp but not by that guy. Then I stripped it down to this:
"_.pedit" "_M" ss "" "_J" "" ""
Then again to what I posted ealier as a macro.
See this post for an explanation.
