Is there anyway to create 1 PDF from a multi-sheet AutoCAD drawing other than merging several PDF's together. I can create a PDF of a multi-sheet Inventor drawing in one step?
Solved by Charles_Shade. Go to Solution.
Assuming by Sheet you are writing about Layouts.
Do you have Publish in your version?
If so click on the Tabs you wish to Publish, right click and choose Publish Selected..., at the top right of the dialog choose Publish Options, then select Type: Single or Multi-sheet.
Or did I completely miss the mark?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Please mark which worked for you so that others who Search this Thread will find the Solution as well.
