AutoCAD Forum
Creating PDF from several sheets
4 REPLIES 4
KevinPinks7697
351 Views, 4 Replies
Is there anyway to create 1 PDF from a multi-sheet AutoCAD drawing other than merging several PDF's together. I can create a PDF of a multi-sheet Inventor drawing in one step?
4 REPLIES 4
Assuming by Sheet you are writing about Layouts.
Do you have Publish in your version?
If so click on the Tabs you wish to Publish, right click and choose Publish Selected..., at the top right of the dialog choose Publish Options, then select Type: Single or Multi-sheet.
Or did I completely miss the mark?
TexShalter
in reply to: KevinPinks7697
try the command "exportpdf"
Thank you worked perfectly
Please mark which worked for you so that others who Search this Thread will find the Solution as well.
”Boost
