AutoCAD 2010/2011/2012
Distinguished Contributor
VB_Autocad_guy
Message 1 of 21 (36,272 Views)
Copy to Clipboard failed
36272 Views, 20 Replies
02-09-2012 08:07 AM
I select an object,
then press Ctrl+C
I get this error message
"Copy to clipboard failed"
Help please.
Patchy
Message 2 of 21 (36,272 Views)
Re: Copy to Clipboard failed
02-09-2012 08:14 AM in reply to: VB_Autocad_guy
List and see what it is, if it is AEC/proxy , no can do.
*Pro
murray-clack
Message 3 of 21 (35,915 Views)
02-14-2012 11:49 AM in reply to: Patchy
A coworker of mine just had the same problem.  What she was trying to copy to the clipboard was a block definition.  I went into the block to look for AEC objects, and none were found.
I ran the AUDIT and PURGE commands, and everything was clear
It turns out the block (a civil plan) had other blocks nested within.  I went into the main block through the block editor, exploded the nested blocks, and saved the main block
I ran the AUDIT and PURGE commands again, and this time it found a whole whack of errors.
Once they were clear, I was able to copy the objects to the clipboard
VB_Autocad_guy
Message 4 of 21 (35,902 Views)
02-14-2012 12:25 PM in reply to: Patchy
What is AEC/Proxy? Can you expound?
Patchy
Message 5 of 21 (35,871 Views)
02-14-2012 01:43 PM in reply to: VB_Autocad_guy
Example of Civil AEC objects:
With plain autocad polylines are polylines, but in Civil, polylines can be convert to AEC Contours, they hold locations, elevations so when you make a cross section trough them, the program generates hills and valleys and calculates cut / fill of how much dirt, etc......
DSM_dude
Message 6 of 21 (35,812 Views)
02-16-2012 07:42 AM in reply to: Patchy
I've ran into this problem when trying to copy annotative objects.
Cad Blog:
http://geauxcad.wordpress.com/
Active Contributor
JF_005
Message 7 of 21 (34,455 Views)
06-19-2012 12:49 PM in reply to: DSM_dude
I just got this bug today for the very fisrt time (in AutoCAD 2012).
I tried to Copy/Paste a BlockReference (for a title block filled with attributes). So I went in Block Editor to check if I could Copy all the entities that way and it worked. So in my case the problem was not the BlockDefenition so I closed the Block Editor.Then I did a "ATTSYNC" command to reset the faulty BlockReference. And after that the Copy/Paste did not failed! :smileyhappy:
VB_Autocad_guy
Message 8 of 21 (34,449 Views)
06-19-2012 02:16 PM in reply to: JF_005
Ah Hah... Not the only one. So Bizare.
VB_Autocad_guy
Message 9 of 21 (33,965 Views)
07-17-2012 10:46 AM in reply to: VB_Autocad_guy
Anyone figured out this problem?
I've never been able to figure it out.
Member
erhard.ehrke
Message 10 of 21 (33,146 Views)
08-26-2012 06:16 AM in reply to: VB_Autocad_guy
Just happend to me - a rare problem. I've tried purging and recovering the drawing without success. Then saved to R12 DXF, closed it, opend the DXF, saved to current 2013 DWG and the problem went. After correcting some settings and defining new layouts the model id fine.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
