I modified an image of a mountain range in Adobe Illustrator and saved it as a DWG file. I am now trying to import it into another CAD program. The drawing has 7024 objects. I've tried "group" and "block" and still end up with 7024 objects. Is there another command I can use to combine the objects and still retain the image quality. The image contains 16 colors. I've attached the drawing.
Any suggestions would be greatly appreciated.
Anthony
Solved by pendean. Go to Solution.
