AutoCAD 2010/2011/2012
jonmcfarlandWS
Message 1 of 9 (283 Views)
Changing the Inch symbol location
283 Views, 8 Replies
12-13-2012 11:11 AM
Is there a way to change the location of the Inch symbol next to a stacked fraction?  As it is the symbol is aligned with the number to the left of the fraction and appears to low and odd (see attached).  I would prefer it closr to the top of the numerator.
Jon
Please select "Accept as Solution" if your question was answered.
curtainwallBIM.blogspot.com
Valued Contributor
Patchy
Message 2 of 9 (276 Views)
Re: Changing the Inch symbol location
12-13-2012 11:32 AM in reply to: jonmcfarlandWS
Of course
jonmcfarlandWS
Message 3 of 9 (265 Views)
12-13-2012 11:42 AM in reply to: Patchy
Thanks Patchy, but that's Mtext rather than a dimension.  I'd like to have the inch symbol higher in a dimension that has a stacked fraction, but normal when it doesn't.
Jon
Valued Contributor
Patchy
Message 4 of 9 (258 Views)
12-13-2012 11:51 AM in reply to: jonmcfarlandWS
I have not seen one done for dimension, I guess no options :smileysad:
**Master
dmfrazier
Message 5 of 9 (248 Views)
12-13-2012 12:32 PM in reply to: jonmcfarlandWS
I've always preferred the look of the diagonal stacked fraction.  Maybe it's because the inch mark works better with it...
Distinguished Mentor
steve216586
Message 6 of 9 (232 Views)
12-13-2012 01:55 PM in reply to: jonmcfarlandWS
If you set the "Fraction Height Scale" to 0.5 it works well.  Your fraction is a total of your text height though so the numbers are half of what the leading number's size.
jonmcfarlandWS
Message 7 of 9 (229 Views)
12-13-2012 01:57 PM in reply to: steve216586
Hi Steve,
Thanks for the suggestion, but still not what I'm looking for.  We generally use reduced size prints and the smaller scale is difficult to read.
Jon
*Expert Elite*
hmsilva
Message 8 of 9 (215 Views)
12-13-2012 03:59 PM in reply to: jonmcfarlandWS
Attached is a lisp I wrote now that does what you want.
Try it, is minimally tested...
if you're not used to dealing with lisp files,
Save the file in a Support File Search Path directory, Load it with "appload" command, then type Inch2top to run the code...
hope that helps
Henrique
Valued Contributor
Patchy
Message 9 of 9 (208 Views)
12-13-2012 04:50 PM in reply to: hmsilva
Fantastic solution
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
