AutoCAD 2010/2011/2012
Active Contributor
Message 1 of 3 (343 Views)
Change rollover tooltips delay time?
343 Views, 2 Replies
10-28-2009 03:16 AM
Hello everyone
Like the title says, is it possible to change rollover tooltips delay time. I often need them to be displayed the moment i hover over object.
Thanks in advance!
Distinguished Contributor
Message 2 of 3 (343 Views)
Re: Change rollover tooltips delay time?
10-30-2009 08:18 PM in reply to: the-trooper
If you're referring to the "extended" tooltips, it's in OPTIONS under the Display tab.
The regular ones are instant on my machine and probably are related to the speed of your system or video card. You might try this though, ""Options" - "User Preferences" tab - uncheck the box under the "Hyperlink" heading on the right side. Apparently it's a "Display hyperlink cursor, tooltip, and shortcut menu" thing." (I found this on CAD-a-Blog)
Hope this helps (though I doubt it),
JD
P.S. "The smell of acrid smoke and horses breath"? Know the reference? If you say, "The Charge of the Light Brigade" you're right... but not the answer I'm looking for.
Active Contributor
Message 3 of 3 (343 Views)
11-01-2009 10:25 PM in reply to: the-trooper
Extended? Hope we're talking about the same thing. Those that appear when you hover over an object are "rollover tooltips", and those that appear when you click on an object are "quick properties".
My system:
Pentium Dual core 2.6 GHz
3 GB RAM
GeForce 9500 GT
Should be enough. But rollover tooltips still display with delay (even with "hyperlink" unchecked).
P.S.
The bugle sounds the charge begins… :-))
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
