AutoCAD 2010/2011/2012
Valued Contributor
bluefox
Message 1 of 2 (425 Views)
Accepted Solution
Can you use the Layer State manager within viewports?
425 Views, 1 Replies
01-31-2013 08:32 AM
Got a question from a client, and I can't find a way to make it work. An ex-coworker said something to me about it, but I haven't figured out how to use it.
Let's say you create a floor plan, and you use the Layer State manager to separate the framing plan, finish plan, reflected ceiling plan, etc. Now, when you go to create a sheet, you xref this plan into model space with all of the layers thawed/on, go to your titleblock in paper space and make a viewport.
Currently, if I click into a viewport and use the Layer State manager to show just the information of the RCP, it will freeze all of the layers I don't need, but it will freeze those layers in model space, instead of just within the viewport. It gets very time consuming doing it the way I always understood to do it; making sure all layers are thawed/on in model space, and then going into each viewport and manually VP-freezing each layer I don't need.
So can Layer States be set up to work within viewports, to only have those layers VP-frozen?
Valued Contributor
bluefox
Message 2 of 2 (420 Views)
Re: Can you use the Layer State manager within viewports?
01-31-2013 08:55 AM in reply to: bluefox
Never mind, I figured it out. Stupid me making threads before trying out all the options first.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
