AutoCAD Forum
Can't select or pick on an object on a solid
2 REPLIES 2
2159 Views, 2 Replies
Good morning. I'm a user or Autocad 2012.
A friend sent me a drawing in which if I try to pick or select an object that is on or behind a solid, the whole solid is selected no matter if I place de cursor on the object or a void space.
The same thing happens if there is no object on or behind the solid because if I merely pick on the space occupied by the solid it gets picked.
I guess it must be some variable set on but I don't know which.
Can somebody please tell me what to do?
Thanks.
2 REPLIES 2
Alfred.NESWADBA
on one side it depends in the visual style you have made active
And as an additional help you can turn on SELECTIONCYCLING (>>>details<<<).
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
in reply to: Alfred.NESWADBA
Thanks for the attention...
The problem was actually that I had 3D Wireframe as shademode. I changed it to 2D and problem solved.
Thanks.
”Boost
