AutoCAD 2010/2011/2012
leothebuilder
Message 11 of 15 (320 Views)
Re: Can't change Arrow type on dimension
08-31-2012 08:47 AM in reply to: matus.brlit
The problem is that you do have overrides in your dim styles.
These overrides  may not appear in the dimstyle dialog box because you may not have used the "override"
button in this dialog box.
Possilbly you may have applied these overrides via "properties"
Use the "list" command and it will show all the overrides you've applied.
matus.brlit
Message 12 of 15 (317 Views)
08-31-2012 09:00 AM in reply to: leothebuilder
ok, it seems that we are getting closer
I did the overrides using properties panel, I can see the overrides using LIST command
but it still doesn't explain, why the dimension doesn't look like it should (with the overriden arrows)
notice, that the ISO-25 dimension was overriden the same way
leothebuilder
Message 13 of 15 (313 Views)
08-31-2012 09:09 AM in reply to: matus.brlit
So you want to have the user arrow "oblique narrow" ?
If so, in the properties palette change the user arrow back to closed filled arrow.
One this change has taken effect, change it back again to "user arrow"
A dialog should pop up that will allow you to select the user arrow block.
Select the "oblique narrow" block.
Patchy
Message 14 of 15 (309 Views)
08-31-2012 09:22 AM in reply to: matus.brlit
Stop pulling your hair out.
matus.brlit
Message 15 of 15 (251 Views)
09-03-2012 02:56 AM in reply to: Patchy
thanks, it works, now let's hope it will work with .NET API too :smileyhappy:
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
