AutoCAD 2010/2011/2012
New Member
Message 1 of 2 (444 Views)
Calculating Areas From Exploded Cross Section
444 Views, 1 Replies
01-21-2013 08:56 AM
I received a cross section file that was created in Micro Station and need to calculate the cut and fill of the project. There is no way to get the 3D files the cross sections were created from. Everything in the file is exploded and flat.
 I was going to hatch under and above the existing grade to find the cut and fill and then thought about the scale of the cross sections. In model space the cross sections are 1=1 H and 1=10 V. When I do a hatch and get the area it is giving it to me way high. If I just divide by 10 I don't think that is right either since the hatch areas are very irregular.
My thoughts on how to solve.
Scale the cross section vertical down by 10 and don't change it horizontally. I don't know if this is possible.
Somehow set the horizontal and vertical scale and hatch above and under to get the areas. I don't know if this is possible either.
Please help.
Message 2 of 2 (436 Views)
Re: Calculating Areas From Exploded Cross Section
01-21-2013 09:03 AM in reply to: alexlazowick
one way is
command block and after being one block modify the y scale to 0.1, then explode
Henrique
EDITED
alexlazowick wrote:
... If I just divide by 10 I don't think that is right either since the hatch areas are very irregular...
As it is scaled vertically 10x, if we divide the area by 10 the result is correct.
Henrique
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
