Does anyone have a version of the CHSPACE.lsp command that has a "copy" option like the one from Intellicad???
This version makes a copy of the selected objects first then moves them into the space you want, leaving the original objects alone in their original space.
Anyone have this version of the lisp?
I don't know about a "version" but its relatively easy to create the lisp for yourself using the command function.
(defun c:chs () ;;DCB2013 (if (=(getvar "tilemode")0) (progn (princ "\nSelect objects") (ssget) (command "_.copy" "p" "" "0,0" "0,0") (command "_.chspace" "p") ) (princ "\nMust be in paper space") ) (princ) )
Thanks dbroad,
That's exactly what I needed.
Is there anyway to make the objects that come into the space, come in on the currect layer?
I'm sure there is. Add a call to the chprop command. You can determine the current layer by:
(getvar "clayer")
