AutoCAD 2010/2011/2012
Patchy
Message 11 of 23 (724 Views)
Re: CAD shuts down at startup
12-16-2011 03:58 AM in reply to: bart.ribbers
That seems to be the source of the problem, without 3.5 it will crash.
(I went thru the same with 2006 and 2008) reformat and reinstall would fix the problem.
my Win7 64 bit has both installed.
bart.ribbers
Message 12 of 23 (717 Views)
12-16-2011 04:38 AM in reply to: Alfred.NESWADBA
Well I deinstalled Framework 4 yesterday, but when I tried to install Framework 3.5 it did nothing... I tried the basic setup and the extended one, and the extended one just unpacked something (which I can't find on the spot it unpacked it) and then did also nothing. So I installed Framework 4 again so I know for sure everything else works.
I'll try to install 3.5 again while I have 4 installed.
And I believe I don't even have C:\ProgramData\. But i'm at school right now so I will check when i'm back home.
Distinguished Contributor
Message 13 of 23 (702 Views)
12-16-2011 08:51 AM in reply to: Patchy
C:\ProgramData is a hidden folder you may need to change your folder view setting to be able to see it.
bart.ribbers
Message 14 of 23 (699 Views)
12-16-2011 08:56 AM in reply to: Dazzman
Thanks i've found it. So I deleted the CascadeInfo.cas but nothing has changed.
And i'm still not able to install Framework 3.5 somehow... I run the setup, it asks for permissions, and then dissapears without doing anything. The full package and just the setup do the same thing.
Patchy
Message 15 of 23 (694 Views)
12-16-2011 09:51 AM in reply to: Patchy
Find the file called
acad.exe.config should be in the same folder as acad.exe
open it with notepad, what does it say in the line
    <supportedRuntime version=" ?????????????????????"/>
bart.ribbers
Message 16 of 23 (681 Views)
12-16-2011 12:59 PM in reply to: Patchy
It says "<supportedRuntime version="v4.0"/>"
Patchy
Message 17 of 23 (679 Views)
12-16-2011 01:24 PM in reply to: Patchy
Got to install that 3.5 in there.
1.  Clean up your TEMP folder by go to:     Start,  Run,  type in:        %temp%
2.  If there are any anti-virus or antispyware applications running, turned them off
3.  Right click on the 3.5 SP1.exe and run it as Administrator.
Write back and let me know how it went.
bart.ribbers
Message 18 of 23 (656 Views)
12-18-2011 10:56 AM in reply to: Patchy
After searching for a while, I found out my computer has Framework 1, 2, 3.5, and 4 installed, it just shows only 4 in "Programs and Features".
I cleaned the TEMP folder, turned my anti-virus off (even deinstalled it), but still no change.
I'm going to make a clean install of my computer, it sometimes helps, and maybe it also fixes some other things.
I'll tell you if it helped when the clean install is done.
Patchy
Message 19 of 23 (653 Views)
12-18-2011 10:59 AM in reply to: bart.ribbers
change v4 in acad.exe.config to 3.5###### as it shows in the Add or Remove Program , shut down and restart PC
before doing anything else
bart.ribbers
Message 20 of 23 (649 Views)
12-18-2011 11:04 AM in reply to: Patchy
I'm not able to, it says "Please check whether if this file is opened in another program".
I've checked in progresses but no AutoDesk program is running.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
