AutoCAD 2010/2011/2012
New Member
thevaz2108
Message 1 of 3 (371 Views)
Building a ramp in 3d
371 Views, 2 Replies
02-13-2013 10:12 AM
Hi
I am trying to bild a ramp in 3d but i've been trying with no success, the ramp have a non common shape. pls look at the acad file to take a loot at the shape.
I need to have the top part at 5531mm and the bottom part at 0 and there is another part which is at 5035mm you can see that in the drrong and the ramp must 100mm thick or something similar. also i need to do it as a solid becouse i need to export it on a different software which only ecrpts solids.
pls help
Distinguished Contributor
Peac3
Message 2 of 3 (355 Views)
Re: Building a ramp in 3d
02-13-2013 12:44 PM in reply to: thevaz2108
MAYBE you can use 3DPOLY, i didn't had any success yet because i don't have time to do some tests but it's possible to extrude something on a 3dpoly and not only on a plane but it can be twisted in space like an Helix
 I would be glad to know how to do that too.
Peac3
Message 3 of 3 (347 Views)
02-13-2013 01:21 PM in reply to: Peac3
I tried with 3DPOLY you can work out something out of it and using the UCS carefully to be align on the right plane before extruding.
Look at this rev 1, i did a curved slope with a very rough 3DPOLY but with time you can draw it with more vertex and do something really precise. Just have to move the 3DPOLY vertex on the Z axis to create the slope, more vertex, more details in the curve.
For the final part, the shape is kind of strange, maybe you can do it larger then substract peaces out of it to shape it like you want!
You are not logged in.
Announcements
    Come hangout with Autodesk Support Specialist and AutoCAD guru Volker Cocco, to learn about Precision Drafting: Object Snaps and Object Tracking on July 31 @ 11:00 AM PST.
    Click here for registration information!
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
