AutoCAD 2010/2011/2012
Distinguished Mentor
TrevN
Message 1 of 42 (4,435 Views)
Autosave, AGAIN!
4435 Views, 41 Replies
06-15-2010 01:55 AM
When oh when are Autodesk gonna fix the auotsave bug? This is a major bug that one day is gonna cost me a lot of time and effort!
Everytime I do a large ammount of drawings thru the publish command, autosave is turned off and doesn't come back, it's bloody annoying and should be fixed. Ahhhhhhggggggggggggggg
Message 2 of 42 (4,420 Views)
Re: Autosave, AGAIN!
06-15-2010 04:40 AM in reply to: TrevN
Forget autosave - turn it off.  It is your job to save.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2014 Edu 64-bit
TrevN
Message 3 of 42 (4,419 Views)
06-15-2010 04:46 AM in reply to: JDMather
Thankyou for that really useful piece of advise!
Now go away, unless you can answer the question.
rkmcswain
Message 4 of 42 (4,411 Views)
06-15-2010 05:11 AM in reply to: TrevN
1) I have agree with JD. Just press Ctrl+S every so often and you'll never need autosave.
2) I have not run across this "bug", but then again, I don't check to see what SAVETIME is set to, so I probably wouldn't notice. As a workaround, you could redefine a command that you use a lot, like ERASE, LINE, or MOVE so that it also sets SAVETIME.
Example:
(defun C:M ()
  (princ "\nShortcut for MOVE")
  (setvar "savetime" 15)
  (command "._Move")
-or- if you want to handle it in a more direct manner, you could use a reactor to 'watch' this variable and set it back whenever it changes. Some example code can be found here: http://cadpanacea.com/node/53
Lastly, have you reported this "bug" to Autodesk?
Message 5 of 42 (4,364 Views)
06-15-2010 08:03 AM in reply to: TrevN
Add this to your ACADDOC.LSP
(defun C:ALERTME ()
(vl-load-com)
(setq VTFRXN (vlr-editor-reactor nil '((:VLR-sysVarChanged . VTF))))
(defun VTF (CALL CALLBACK / vtf:nst)
(if (and
(= (strcase (car CALLBACK)) (setq str "SAVETIME"))
(eq (getvar str) 0)
(progn
(princ (strcat "\nWarning: The " (getvar "CMDNAMES") " command has changed your Autosave settings to 0."))
(if (setq vtf:nst (getint "\nEnter new value for SAVETIME <10>: "))
(progn
(setq vtf:st vtf:nst)
(setvar "SAVETIME" vtf:st)
(progn
(setvar "SAVETIME" 10)
(setq vtf:st 10)
(setq vtf:st (getvar "SAVETIME"))
(if (= (getvar "SAVETIME") 0)
(progn
(setq vtf:st (getint "\nSAVETIME is currently set to 0 minutes\nEnter new value for SAVETIME: "))
(c:alertme)
TrevN
Message 6 of 42 (4,361 Views)
06-15-2010 08:31 AM in reply to: RStillwell
Thankyou.
Valued Contributor
Message 7 of 42 (4,213 Views)
06-18-2010 05:42 AM in reply to: rkmcswain
I make QSAVEs as I draw but only when I'm happy with the drawing, I don't blindly Save as a crash recovery tool. We have Autosave for that. And since it saves to a temporary file rather than overwriting your orignal it gives you options if you need to recover a file - and, oh my god, does Autocad know how to corrupt a file...
I've experienced Autosave switching off too, so I simply added a line to my acaddoc.lsp file to ensure it is always on at the start of a session at least.
rkmcswain
Message 8 of 42 (4,163 Views)
06-18-2010 08:31 AM in reply to: TrevN
TrevN wrote:
Thankyou.
So did you or Autodesk remove the reply to JD?
Valued Mentor
stevenelliott3894
Message 9 of 42 (4,156 Views)
06-18-2010 08:40 AM in reply to: rkmcswain
Interesting how things work here. Interesting indeed.
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
Valued Mentor
hardin
Message 10 of 42 (3,857 Views)
09-08-2010 10:05 AM in reply to: TrevN
I'm glad you mentioned the publish issue. That IS what does it... We've been trying to figure this out for ages.
I agree, save when you are ready to save... not just arbitrarily as with a redefined 'move' command, although, I do tend to type QS pretty frequently. Either way, it's nice to have those Autosave files when you need them.
I'm using the Alertme.lsp now. I stuck it in the LISP portion of our Enterprise menu that's on the network. Works well. It's a bit annoying when it intercepts the publish command, but it's livable. Just hit return and its all good.
Learn, Practice, Get Better
http://autocad-lkh.blogspot.com
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
