AutoCAD 2010/2011/2012
*Expert Elite*
Message 31 of 36 (425 Views)
Re: Autocad gives the wrong area for a polyline
07-17-2012 02:38 PM in reply to: TerryDotson
Wait a min! Didn't you say
"The AREA command can return an invalid number, while the underlying API (Polyline Object .Area Property) returns the correct value."
I'm getting the wrong answer both ways in that example, unless I'm misunderstanding you?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Valued Mentor
TerryDotson
Message 32 of 36 (420 Views)
07-17-2012 04:41 PM in reply to: troma
Unless you are using some form of programming language to obtain the Area property supplied by the API, you are not seeing it (the correct value).  For example this small LISP routine will dump the properties of an object, including the area.
*Expert Elite*
Message 33 of 36 (411 Views)
07-18-2012 05:50 AM in reply to: TerryDotson
I tried to use that lisp, I get:
Command: DUMP
Select Object: ; error: bad argument type: lentityp nil
Any ideas?
*Expert Elite*
Message 34 of 36 (404 Views)
07-18-2012 09:31 AM in reply to: troma
Try this (slight fix)
*Expert Elite*
Message 35 of 36 (402 Views)
07-18-2012 09:39 AM in reply to: dbroad
Thanks for the fix.
But have a look Terry, I'm still getting the wrong area:
New Member
Message 36 of 36 (265 Views)
Re: Autocad gives the wrong area for a polyline can be corrected
02-07-2013 01:40 AM in reply to: troma
What I found is that, copy the polyline amd move towards 0,0. List it, check with area command. I hope u may satisfy up to maximum extent.
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
