AutoCAD 2010/2011/2012
Active Member
ccti-reg
Message 1 of 4 (1,690 Views)
Autocad 2012 x 64 - Windows 7 x64 - Crash when printing 11x17
1690 Views, 3 Replies
01-24-2012 12:48 PM
I'm having an issue right now. I have multiple HP printer (mainly laserjet 9050, laserjet 5100) that have a hard time printing 11x17 in autodesk.
When the user press print, Autocad crash. With the laserjet 5100, the problem was "resolve" by adding another print queue with postscript drivers. Now, I don't feel like adding more then 35 print queue in postscript just so user can print in Autocad directly.
The other work arround I found is to print into pdf creator then print the PDF. You can understand the frustration of the users. This issue exist since autocad started doing 64-bits version.
P.S. Problem with your forum. When putting more then 10 tags in the Message Tags field, I get error "
pendean
Message 2 of 4 (1,681 Views)
Re: Autocad 2012 x 64 - Windows 7 x64 - Crash when printing 11x17
01-24-2012 01:39 PM in reply to: ccti-reg
In the Print-Plot discussion area http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30 the recommendation is to install the HP Universal drivers for a fix.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
Message 3 of 4 (1,665 Views)
01-24-2012 03:52 PM in reply to: ccti-reg
I have not had consistent success with the "Universal Driver"
Another common workaround (which I am still using) is to create a custom paper size that is 11x17. My system will crash if I use autodesk's 11x17, but if I use a custom paper size (of exactly the same dimensions) it prints just fine...
Good luck.
Active Member
ccti-reg
Message 4 of 4 (1,656 Views)
01-24-2012 05:28 PM in reply to: entropist
Ok, I changed the driver for the latest universal pcl 5, we'll see what it does.
I've also inform the teacher that he can try using a custom paper size. I'm just wondering how the printer will handle it. Sometime the printer is so dumb that someone send a custom 8.5X11 and it request to put this type of paper into the printer instead of using the one already there.
Thanks again, I'll keep in touch with the result.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
