AutoCAD 2010/2011/2012
Active Member
sortego
Message 1 of 11 (5,347 Views)
Autocad 2011...can't find express tools.....help menu missing
5347 Views, 10 Replies
05-18-2010 01:40 PM
Just installed the upgrade from 2010 to 2011 and now i have NO express tools. I did install them though. Also when i go to help, its saying cant be found. Any ideas????
One more thing; in 2010 every so often when i have acad open and then open internet exporer, it would shut down my autocad!!!!!????
*Dean Saadallah
Message 2 of 11 (5,347 Views)
Re: Autocad 2011...can't find express tools.....help menu missing
05-18-2010 02:36 PM in reply to: sortego
If you think you installed them, just type EXPRESSTOOLS at the command line.
If that does not work, they did not get installed. Try again.
OPTIONS command, set Help to be local to your PC, and not on the Internet
(default).
Dean Saadallah
http://LTisACAD.blogspot.com
Active Member
sortego
Message 3 of 11 (5,347 Views)
05-18-2010 02:55 PM in reply to: sortego
Thanks, i got the express tools working, but no luck with help menu.
*Dean Saadallah
Message 4 of 11 (5,347 Views)
05-19-2010 04:18 AM in reply to: sortego
R2011 alternate Help files:
AutoCAD 2011 online Help http://docs.autodesk.com/ACD/2011/ENU/landing.html
AutoCAD 2011 CHM-Based Help
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=15068206&siteID=123112&linkID=9240618
AutoCAD 2011 Help in PDF format
http://docs.autodesk.com/ACD/2011/ENU/pdfs/PDF%20Documentation.html
AutoCAD Wiki Help Beta http://wikihelp.autodesk.com/Product_Help/AutoCAD
Dean Saadallah
Active Contributor
StevekBenko
Message 5 of 11 (4,904 Views)
11-24-2010 12:17 PM in reply to: sortego
I am also new to 2011, upgraded from 2007. I did not load autocad on to my system so Im not sure where to go from here to aquire the expresstools. I did type "expresstools" into the command line and the response was "unknown command". Could anyone help point me in the right direction?
*Pro
nestly
Message 6 of 11 (4,902 Views)
11-24-2010 12:30 PM in reply to: StevekBenko
Express Tools are installed by the AutoCAD setup program.  Insert the AutoCAD disk and  the setup program should start automatically allowing you to ADD Express Tools to your install
or
Start > Settings > Control Panel > Add Remove Programs > AutoCADxxxx > Change/Remove > Add/Remove Features > Express Tools  (you may still need the AutoCAD disks to install Express Tools)
Active Contributor
StevekBenko
Message 7 of 11 (4,893 Views)
11-24-2010 01:32 PM in reply to: nestly
THAT'S WHAT I NEEDED!! Thank you very much. The office won't even know how happy they will be.
Distinguished Contributor
jeff.whitney
Message 8 of 11 (4,237 Views)
02-04-2011 01:42 PM in reply to: sortego
Even after doing all that, I get the same error message
*Pro
Modman_4
Message 9 of 11 (4,228 Views)
02-04-2011 02:38 PM in reply to: jeff.whitney
Try searching these forums (2011) on Help questions. There is an older post from last spring where a link was given to a downloadable Help file in the old CHM format. Good luck! :smileyhappy:
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
jeff.whitney
Message 10 of 11 (4,221 Views)
02-04-2011 03:04 PM in reply to: Modman_4
Thanks for the reply - but even worse - NO CHM help files work on my computer!  None, not just ACAD, but none at all.  Have tried several things, but nothing works.
You are not logged in.
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
