AutoCAD 2010/2011/2012
New Member
av8or-dave
Message 1 of 6 (559 Views)
AutoCad 2012 custom paragraph Spacing
559 Views, 5 Replies
09-01-2012 10:46 AM
I just started working for a new employer as a 2012 AUTCAD Tech:  they have only used old school DTEXT for everything (what a pain compared to multi-text "MTEXT").
Problem: I converted several single line Dtext to Mtext (.075 test height) paragraphs but can not achieve the same spacing they have been using (.225) because .025 is not an availalbe increment in the parapgrah & line spacing selection.  Is there a way or a LISP that will allow me to add custom spacing choices to the Line/Paragraph spacing default list?
Then I can upgrade so much and work faster, yet maintain the standard spacing already set via snap grid settings.
Dave
*Expert Elite*
pendean
Message 2 of 6 (535 Views)
Re: AutoCad 2012 custom paragraph Spacing
09-04-2012 05:57 AM in reply to: av8or-dave
AutoCAD's built in limit is 1/4" through 4": there is no lower or high options available.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
estiles
Message 3 of 6 (469 Views)
Re: Autocrat 2012 custom paragraph Spacing
11-30-2012 02:27 PM in reply to: av8or-dave
It would be nice to have smaller spacing.  1/4" is too much.  The font size or half the font size would look much better so 0.1 or 0.05.
Wish List!
New Member
QCAD125
Message 4 of 6 (417 Views)
02-09-2013 07:58 PM in reply to: av8or-dave
There is a cumbersome workaround
If you want your paragraph spacing set to 1/8" but it wont let you because its lower than 1/4", you can ...
Use SCALE to make your MTEXT twice as large
Set the MTEXT paragraph setting to 1/4"
Use SCALE to make your MTEXT half as large
Your MTEXT is now back to your original size with a 1/8" paragraph spacing. You will have to figure out your own specific value to scale UP/DOWN your text to change your spacing to what you need it to be, but once you do it once it will get you what you need with a minimum of extra effort. Let me know how it works for you.
Not sure why they set the min value for that variable that high; or why it doesnt have an option to make it a factor of the line spacing instead.
area51visitor
Message 5 of 6 (409 Views)
02-10-2013 01:05 AM in reply to: QCAD125
Can't you simply click the properties open and change line-spacing to whatever you want?
- Brian
"Very funny, Scotty. Now beam down my clothes."
estiles
Message 6 of 6 (393 Views)
02-10-2013 05:10 PM in reply to: av8or-dave
Thanks av8or-dave,  That work around works great.  Strange that we have to do that.
You are not logged in.
Announcements
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
