AutoCAD 2010/2011/2012
Active Contributor
rjimenez00
Message 1 of 8 (1,199 Views)
AutoCAD does not recognize the Object Snap commands
1199 Views, 7 Replies
04-23-2012 03:00 PM
Hi everyone!
The problem is that AutoCAD 2010, does not recognize any object snap commands, all the other comands work just fine.
I have reinstalled the program and don´t work.
What could be?
Thanks for your time
Alfred.NESWADBA
Message 2 of 8 (1,198 Views)
Re: AutoCAD does not recognize the Object Snap commands
04-23-2012 03:03 PM in reply to: rjimenez00
Do you have a sample for "does not recognize"?
If I now imagine you e.g. start command _LINE and then use _ENDPOINT as objectsnap your cursor does not show the snap-symbols when you come close to a line?
Have you alread looked to the command _OPTIONS how the settings for OSNAP-symbols etc are configured.
Or is "does not recognize" anything completley different?
Anyway: you did your tests always in a new template (best would be if you use an original AutoCAD-template).
- alfred -
Alfred NESWADBA
Active Contributor
rjimenez00
Message 3 of 8 (1,197 Views)
04-23-2012 03:11 PM in reply to: Alfred.NESWADBA
For example if I have a circle I can not use the command "qua", even if I use the icon directly.
Alfred.NESWADBA
Message 4 of 8 (1,195 Views)
04-23-2012 03:13 PM in reply to: rjimenez00
can you make a screenshot from your command-line after you tried it?
- alfred -
Alfred NESWADBA
Active Contributor
rjimenez00
Message 5 of 8 (1,192 Views)
04-23-2012 04:00 PM in reply to: Alfred.NESWADBA
Of course, but first I have to reinstall it.
The message is simple, it tells you when you enter a command that does not exist.
Thanks for your time.
Alfred.NESWADBA
Message 6 of 8 (1,188 Views)
04-23-2012 05:10 PM in reply to: rjimenez00
QUA or ENDP or any other objectsnap is no command and can't be used as such one!
Objectsnaps can only be used at the time AutoCAD asks for to show/input a point. That was the reason why my sample/my question was:
When you started the command _LINE AutoCAD asks you for a point, and now you can follow with _QUA to activate the osnap for quadrant so only these points will be used.
- alfred -
Alfred NESWADBA
pendean
Message 7 of 8 (1,168 Views)
04-24-2012 05:27 AM in reply to: rjimenez00
You have to be in a command before you can use an Osnap like QUA: is that the problem?
A test:
At the command line, type
OSMODE
Then enter
123
Now start the LINE command, and hover your cursor over a quadrant of a circle, it should attach there unless your PICKBOX is too small or you are not at a quadrant (not every edge of a circle is a quadrant).
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
rjimenez00
Message 8 of 8 (1,121 Views)
04-30-2012 11:35 AM in reply to: pendean
You are rigth.
Thank you.
You are not logged in.
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
