Freezes on open command. Literally takes 4 minutes for file folder to pop up. I am on a network of two computers. CAD folders on other computer but does this even when files on my hard drive
and if you disconnect your workstation from the network and open then the file-open-dialog, is it then open more quick?
- alfred -
if the start from Windows-explorer (using double click) is fast then I guess you have some issues with your network configuration or how one workstations/user is recognized from the other one. Do other software packages have the same time span, e.g. when you use word to open a doc from the other pc?
- alfred -
>> froze up one recent morning when detailer's computer hard drive crashed
Was it necessary to reinstall anything on that workstation? If so there maybe one or more directories or files missing your AutoCAD LT is searching for.
>> AT&T switched us over to U-Verse line replacing
That points again to "something wrong with network settings".
If it's possible to have your 2 computers connected but you disconnect your network from internet try that:
- alfred -
