AutoCAD 2010/2011/2012
Active Member
vishu7334
Message 1 of 4 (690 Views)
Accepted Solution
AutoCAD 2012 stops working without showing an error when I copy a surface
690 Views, 3 Replies
09-05-2011 12:24 AM
AutoCAD 2012 just stops when I try to copy a surface. It just says "(Not Responding)" on the window title bar. All I have to do is shut the ACAD process down and restart ACAD. But as soon as I start copying a surface and put it wherever I want, it just stops responding.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (689 Views)
Betreff: AutoCAD 2012 stops working without showing an error when I copy a surfa
09-05-2011 01:01 AM in reply to: vishu7334
when an application "stops responding", it's always necessary to know, what the task-manager says. Has the AutoCAD-task a CPU-load of 0 % ore more? Also imortant: how much memory is AutoCAD using, how much memory is built in your workstation (and are you running 32bit or 64bit).
Next is: how do you copy a surface. I see very often, that the windows-copy mechanism (^C ^V or "Edit==>Copy" / "Edit==>Paste") is used. If you do copy an AutoCAD-object within the same drawing, then the windows-copy is the worst way I can do; the way the object-data is running through your operating-system is like travelling to the moon and (hopefully) back.
Doing a copy within the same drawing, please us the AutoCAD-command _COPY!  So my question is, have you tried with the AutoCAD-command? Our did you have a problem with copying a surface from one drawing to another?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Member
vishu7334
Message 3 of 4 (685 Views)
09-05-2011 02:08 AM in reply to: Alfred.NESWADBA
My system is running on Windows 7 32 bit OS with 4GB RAM. I was trying to copy the surface within the drawing and I WAS using AutoCAD command for copying. But it turned out that the culprit was someone else. It's layer filters. Too many layer filters overloads the CPU I guess. So I deleted all the layer filters and here I have it running again.I can now successfully copy surfaces which I want. Thanks for replying.
*Expert Elite*
Alfred.NESWADBA
Message 4 of 4 (683 Views)
09-05-2011 02:20 AM in reply to: vishu7334
Wow, thank you for the feedback, that's new to me.
- alfred -
Alfred NESWADBA
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
