AutoCAD 2010/2011/2012
Member
guitarchic0516
Message 21 of 32 (2,398 Views)
Re: AutoCAD 2012 freezes or lags when using the copy command
10-24-2011 07:58 AM in reply to: Jlasante
SORRY, Autodesk! After I saved my file and then opened it back up after filering the layer, the laggin was fixed!
New Member
RudyMartignago4984
Message 22 of 32 (2,233 Views)
11-23-2011 02:06 PM in reply to: guitarchic0516
I have a lagging problem when I select Layer Isolation 10sec each time. we are using V2012. Any suggestion?
New Member
MattConlin
Message 23 of 32 (2,046 Views)
01-09-2012 11:50 AM in reply to: Jlasante
I also had this problem.  It happened to me on two different computers, one had autocad LT 2012 , the other had autocad 2012.  I also had a bazillion layer filters, so I deleted them, and the lagging problem persists.
I'd love to find a solution to this.
New Member
MattConlin
Message 24 of 32 (2,044 Views)
01-09-2012 11:54 AM in reply to: MattConlin
I also should add that I notice the lagging in any type of copy related command such as array or mirror.
New Member
triple20
Message 25 of 32 (1,972 Views)
01-16-2012 08:47 AM in reply to: guitarchic0516
Try turning off the Dynamic UCS. (UCSDETECT change to 0, default is 1). It worked for me.
New Member
Message 26 of 32 (1,437 Views)
05-11-2012 10:39 AM in reply to: Jlasante
Deleting extra layer fliters solved this problem for me.
Valued Contributor
Message 27 of 32 (1,317 Views)
06-25-2012 01:36 PM in reply to: Jlasante
I have experienced the same issue. When I paste the cross hair freezes and the drawing crashes. That is the problem, now what is the solution.
Valued Contributor
Message 28 of 32 (1,316 Views)
06-25-2012 01:39 PM in reply to: pendean
I find that extremely impossible to believe, ACAD 2011 and 2012 have been prone with MANY issues, I'm running WIN 7 64 bit anything less and you have snail CAD. Does Autodesk actually run their software in real world environment?
Just curious.
Valued Contributor
Message 29 of 32 (1,316 Views)
06-25-2012 01:40 PM in reply to: Patchy
It is NOT RAM related. It is poor code related.
New Member
Message 30 of 32 (1,265 Views)
07-12-2012 09:37 PM in reply to: jaich
Hi. My self sandeep chauhan, I also faced the same problem in autocad 2012 when I try to copy clip something hatched.
I simply turn off the notification about the associative hatch, which pop up in upper right corner of autocad.
Hope this will work for you all also.
You are not logged in.
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Connect with AutoCAD
Twitter
Facebook
Blogs
Pinterest
Youtube
